It is currently Sun Aug 03, 2025 10:45 pm
 Post subject: Carving Neck
PostPosted: Mon Feb 02, 2009 12:54 pm
I have a neck that is ready to carve. Is it best to glue the fingerboard on before carving? Any recommendations before I begin?
 Post subject: Re: Carving Neck
PostPosted: Mon Feb 02, 2009 1:01 pm
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
Carve the neck before attaching the fingerboard for the initial carving. The neck can change (bow, twist) as you remove material. You will want to be able to straighten this all out before attaching the fingerboard. Just make sure you do not carve all the way to the edge by the fingerboard to make sure you don't create a "divot". You can blend this edge with the fingerboard after it is glued to the neck
John Ressler
PostPosted: Mon Feb 02, 2009 1:08 pm
I glue the fingerboard to the square neck, then carve. JRessler has a good point about watching for movement as you carve the neck. I level the fretboard very late in the process to correct any warping, but i have never found it to be a big deal with nice well seasoned wood.
Jordan Aceto
Ithaca, NY
PostPosted: Mon Feb 02, 2009 1:45 pm
Well, it looks like John and Jordan have different approaches... Does anyone else want to weigh in? This is my first neck carve. I'd like to see if others have opinions - not that I don't respect John's and Jordan's opinion. Thanks guys, for your responses...
PostPosted: Mon Feb 02, 2009 1:52 pm
I glue first, but my necks are laminated and won't move around anyway.But i do cut out the basic shape before glueing then lap the neck flat before glueing the fretboard on.If your necks aren't laminated, i would glue last as they might move around on you during the carving.I'm doing a neck right now come to think of it.
PostPosted: Mon Feb 02, 2009 2:47 pm
Steve, when I see two talented builders with different opinions, that tells me that both approaches will work just fine. You just decide then which will work best for you.
PostPosted: Mon Feb 02, 2009 3:36 pm
like steve said, there are many ways to skin a cat and they all work.
i glue on the fretboard, then flip it over on the router table and have the bearing of a flush trim bit ride the edge of the fingerboard.
from there i start the real carving. in my case i use three piece laminated necks and only true the fingerboard once it's attached to the body. no problem with movement.
phil
PostPosted: Mon Feb 02, 2009 4:00 pm
First name: Tracy
Last Name: Leveque
State: CO
Steve,
I've got a pretty good tutorial on my website here:
http://www.luthiersuppliers.com/products/p10-2.html
This is straight from the Colorado School of Lutherie. You can do it either way, but this is just another way to do it. There is no perfect "right" way. Good luck and hope this helps!
PostPosted: Mon Feb 02, 2009 4:30 pm
Last Name: Ressler
City: Sandwich
State: IL
Todd Stock wrote:
- Not a bad idea to shape the heel and get the peghead shaped before the board goes on - setting the neck angle and centerline is easier (including flossing), and you don't have to worry about dealing with the fretboard when routing.
For me, this is the main consideration for not attaching the fingerboard. Fitting the neck to the body is so much easier with out the fingerboard extension in the way (at least for the method I use). Something to consider...
John Ressler
Right, to clarify, i shape the headstock and heel area- then fit the neck to the body- then glue the fretboard- then carve the neck.
All of Todd's points are good ones.
Jordan Aceto
Ithaca, NY
Users browsing this forum: Dmaxwell and 33 guests
